SRAM Interbike Virtual Trade Show Booth 2009 » Matchmaker X
Matchmaker X
Matchmaker X Clamp
MatchMaker X is a singular clamp that mounts both the brake lever and the shifter, reducing weight and redundancy, while maximizing adjustability and bar space. You can position your shifters on the bar medially/laterally as you like, and the shifter lever can be repositioned as well. You can also rotate them on the bar to put them exactly where you need them. MatchMaker X also supports the XLoc remote suspension control. It’s the XX philosophy in action.
XX Shifter
One of the lightest and most compact shifters ever created, the XX Trigger features a fully adjustable carbon fiber lever, resulting in minimal weight with maximized durability. Pair the XX Trigger with the MatchMaker™ X clamp to streamline your handlebar setup. The XX Trigger maintains the legacy of X.0™ shifting with new features and technologies optimized for 2×10 and Exact Actuation.
