/* php endif; */ ?>
Interbike 2011 , Virtual Trade Show Booth
| SKS Raceblade Long Fender Set |
| SKS is once again revolutionizing the fender market with a new quick release fender that extends splash coverage to the max. The new Raceblade Long, available in black and silver, features quickrelease mounting with fixation at the brake mount and skewers. The fender is completely adjustable to fit any wheel radius and features a sliding profile for perfect coverage where you need it. Raceblad Long can be mounted in minutes. Works on bikes with no eyelets and low clearance. The 6-inch mudflap extension gives optimal spray coverage to drafters or can be removed to save weight. Fits tire size 700×18-23, available in black and sliver. Raceblade Long is designed and produced at the SKS factory in Sundern Germany. more… |
| SKS Longboard Fender Set |
| more… |
| SKS Spaero Mini Pump |
| more… |
| SKS Airkompressor 12.0 |
| more… |
Related posts:
