Park Tool Interbike 2010 Virtual Tradeshow Booth » Head Tube Cutter for IS headsets
By adam September 28, 2010
The Park Tool 756s set will ream and face the head tubes of bike using the Integrate Headset system compatible with the Cane Creek® standard. Set includes two cutters. There is an upper cutter and a lower cutter. The two are not interchangeable. Both will cut the frame to the 45-degree standard. The cutter mount on the Park Tool HTR-1 Headtube Reamer and Facer. Some frames may require the use of the 750 Centering Cone Adaptor. The 750 increase the size of the centering cone
