Knolly Interbike Virtual Trade Show Booth 2009 » Podium
PODIUM Overview:
To say that we at Knolly are stoked on this frame would be a massive understatement: 3 years in development, the 2010 Podium embodies everything that we have learned since the start of Knolly Bikes. The Podium is purebred racing performance: 35 BB height 13.9” , a 64 degree head angle and one of the most acclaimed suspension systems on the market lead to a high performance bike that’s fast, stable and predictable in every situation. Four by 4 linkage technology enables you to brake later into the corners, sprint quicker out of the them and pedal like mad in between!
This bike is fast – and we mean really fast – yet it’s still super nimble in the tight technical sections. The Podium is designed to balance the needs of a light weight racing bike while still providing the lateral rigidity to hold the tightest lines through corners.
Four by 4 Linkage technology: working to make you go faster.
· Great pedaling
· Fully active braking
· Superior lateral rigidity
· Super supple initial stroke
· Progressive big hit resistance
· Absolutely dialed frame geometry
PODIUM DH at a glance:
Rear travel: 213mm (8.4”)
Recommended fork travel: 203mm (8”)
Full length seat tube: 31.6mm seat post
Head tube: 1.5”
Rear hub: 150 x 12mm thru axle
Tire clearance 26 x 3.0”
ISCG05 tabs: integrated into bottom bracket shell
Dropouts: fully replaceable 9mm (3/8”) thick derailleur hanger and disc mount
