By admin September 12, 2011
| Our premier all-mountain performance bike. With a re-designed tapered headtube (1 1/8″-1 1/2″), internal sealed cartridge headset, All new Avid X.0 brakes, upgraded cockpit, new graphics, Full SRAM X.0 drivetrain and combined with the Fox Talas Factory 150mm fork and Float RP23 rear shock, the Nebo Peak is the ultimate all-mountain bike. The Nebo Peak brings higher-end components, including full SRAM X.0, 2×10 drivetrain, carbon X.0 crankset, Avid X.0 brakes with heat shedding rotors, Fox Talas 150mm fork with 15mm thru-axel, tubeless ready wheels and tires, and overall lighter weight – 28 lbs. We have also re-designed the bottom bracket shell. With more machining and refining, we have made it lighter stronger and added ISCG mounts for more drivetrain options. |
| YEAR/MODEL |
2012 Nebo Peak |
| U.S MSRP |
$3499 |
| CATEGORY** |
All-Mountain |
| SIZES |
16", 17", 19", 21" |
| COLORS |
Flat White, Flat Black, Flat Red |
| FRAME |
Fezzari Racing Design F6A tapered, 6061 hydro-formed Aluminum, 6" travel |
| FORK/TRAVEL |
Fox 32 Talas Factory, Fit RLC, 150mm Travel, 15mm Thru Axle, Tapered |
| REAR SHOCK/TRAVEL |
Fox Float RP23 |
| BRAKES |
Avid Elixir CR Frnt: 185 mm R: 160mm |
| CRANKS |
Sram X.0 2×10 26T/39T |
| FRONT DERAILLEUR |
Sram X.0 |
| REAR DERAILLEUR |
Sram X.0 10spd |
| HANDLEBAR |
Truvativ Stylo Team 31.8, 680mm length, 40mm rise |
| CHAIN |
KMC X10 |
| BOTTOM BRACKET |
Sram GXP Sealed Bearing |
| RIMS |
Mavic XM819, Tubeless Ready |
| HUBS |
Frnt:Shimano SLX 15mm Thru Axle R: Shimano SLX QR |
| SPOKES |
15 G Stainless Steel w/ Brass nipple |
| SADDLE |
WTB Rocket V |
| SEATPOST |
Fezzari Alloy |
| SHIFTERS |
Sram X.0 2×10 |
| STEM |
TruVativ Stylo Race |
| TIRES |
Maxxis Crossmark 26X2.25 |
| SPEEDS |
2×10 |
| HEADSETS |
FSA B-53K, |
| FREEWHEEL/CASSETTE |
Sram PG-1070 12-36T |
| PEDALS |
Wellgo Racing Flats |
| GRIPS |
Fezzari Lock-on |
| BRAKE LEVERS |
Avid Elixir CR |
| Fezzari Nebo Peak Swing Arms |
| Fezzari Nebo Peak Chainstay |
| Fezzari Nebo Peak Linkage |
| Fezzari Nebo Peak Downtube |
More info on the Nebo Peak @ Fezzari.com
