/* php endif; */ ?>
Interbike 2011 , Virtual Trade Show Booth
| Fezzari Nebo Peak |
| Our premier all-mountain performance bike. With a re-designed tapered headtube (1 1/8″-1 1/2″), internal sealed cartridge headset, All new Avid X.0 brakes, upgraded cockpit, new graphics, Full SRAM X.0 drivetrain and combined with the Fox Talas Factory 150mm fork and Float RP23 rear shock, the Nebo Peak is the ultimate all-mountain bike. The Nebo Peak brings higher-end components, including full SRAM X.0, 2×10 drivetrain, carbon X.0 crankset, Avid X.0 brakes with heat shedding rotors, Fox Talas 150mm fork with 15mm thru-axel, tubeless ready wheels and tires, and overall lighter weight – 28 lbs. We have also re-designed the bottom bracket shell. With more machining and refining, we have made it lighter stronger and added ISCG mounts for more drivetrain options. more… |
| Fezzari Cascade Peak |
| more… |
| Fezzari Widows Peak |
| more… |
Related posts:
