By adam September 27, 2010
Virtue Team
Virtue Team
Redesigned for 2011, the all-new Virtue Team features cutting-edge carbon engineering technologies and the award-winning Equilink suspension travel—which can be adjusted to either 120mm or 130mm to master all types of terrain. The new frame, made with UHC Advanced carbon fiber, has a ControlTaper headtube for improved front-end stiffness, plus updated, more stable geometry. With SRAM XO components and Mavic Crossmax ST wheels, this is the lightest, fastest Virtue ever.
Features
Frame: Felt Virtue Equilink Trail Adjustable 120/130mm Travel Carbon Suspension Frame, UHC Advanced Carbon Fiber, Dynamic Monocoque Construction. 1 Piece Full carbon rear triangle including dropouts
Fork: RockShox SID RLT 120mm Travel
Drivetrain: Sram X-O 10 Speed shifters, front and rear derailleur and crankset 2pc crankset, Sram 10 speed chain and cassette
Components: Felt Devox Carbon riser bar, Felt Stem, Trail lockon grips, NiTi rail saddle and carbon seatpost. Sram XO hydraulic disc brakes
Wheelset: Mavic Crossmax ST Wheelset, Continental X-King tires
Accessories: N/A
Finish: Matte Carbon
Sizes: Mens 26 x S (15.5), M (17.5),L (19.5),XL (21.5)
Specs
Weight:
Frame: Felt Virtue Equilink Trail Adjustable 120/130mm Travel Carbon Suspension Frame, UHC Advanced Carbon Fiber, Dynamic Monocoque Construction. 1 Piece Full carbon rear triangle including dropouts: Control Taper 1.125/1.5 Integrated Head Tube, , Hi clearance seat and chainstay yokes. Dingle guard Replaceable Kevlar. Down Tube protector. Bolt on Kevlar chain watcher. Disc specific, Replacable Derailleur Hanger.
Shock: RockShox Monarch RT3: Adjustable Floodgate, inc. rebound adjuster , With Custom Valving
Fork: RockShox SID RLT 120mm Travel: with tapered 1 1/8- 1.5 Alloy steerer All Travel Adjust Dual Air Air pressure via dual Schrader valves Motion Control Damping External rebound, low speed compression to ‘Lock’ with external Floodgate Magnesium, post mount disc brake with Power Bulge Forged Lowers, AL 66 TV aluminum Crown,. 32mm, 7000 series straight wall aluminum Stanchions, low friction anodized with sag gradients, Includes Poploc Remote
Headset: Fully Integrated 1-1/8/1.5 Aheadset for tapered Head tube: Sealed Cartridge Bearing, with Felt Tornado Alloy Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
Stem: Felt MTB oversized 3D-Forged Design: 4-Bolt Handlebar Clamp, with Hole in Front Clamp, 1-1/8 Threadless, for 31.8mm Handlebar, 7 Degree Rise, with CP Cromo hardware;Sizes S=90mm, M=100mm, L/XL= 110mm
Handlebar: FELT Devox RXC Carbon UHC Nano Handlebar: 31.8mm clamp diameter, 30mm Rise 8 Degree Rear Sweep, 4 Degree Up Sweep, Width: 640mm
Grips: Felt XC Trail Single clamp Lock-On wing grips: With alloy bolt, Nylon base, Pruven rubber grip, Color matched
Bar Ends: Felt Wing Icon end plugs
Shifters: Sram X-O 1:1 trigger shifters, 10-speed
Front Derailleur: Sram X-O 10 speed
Rear Derailleur: Sram X-O 10 speed with Carbon Cage
Crankset: Sram X-O 3 x 10 GXP 10 speed: with allloy 42/33/22T rings Sizes; Lengths: S=170mm; M/L/XL=175mm
Chainwheel n/a
Chainguide: n/a
Bottom Bracket: With crankset
Pedals: n/a
Chain: Sram PC-1070 Super-Narrow for 10-speed
Freewheel: Sram PG-1070 10 speed 11-32T
Brake Levers: Sram X-O
Brakes: Sram X-O Hydraulic Disc Brake: Rotors: 185mm Front 160mm Rear
Cables: Custom Felt Cable Set: Featuring Stamped Felt Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and one Alloy CNC Alloy ferrule at RD, Brake hose supplied with Brakeset
Saddle: Felt Mountain Design,: Low Side Profile Look with Performance fit Top, double-Density Base, Ni-Ti Rails
Seat Post: Felt Carbon Post with Twin Clamp Design: Micro-AdjustSizes, Sizes: S=30.9mm x 350mm, M/L/XL=30.9mm x 400mm
Seat Post Clamp: Felt Bolt-Type: Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 34.9mm
Rims: Mavic Crossmax ST Wheelset: Maxtal 19mm rims with ISM Milling, oversize Aluminum 9mm Axle front hub oversize Aluminum Rear with Aluminum Axles 24 Spokes front and rear and Integrated M7 aluminum nipples
Front Hub: with Wheelset
Rear Hub: with Wheelset
Spokes: with Wheelset
Tires: Contenental X King RS: SL Folding Bead 26 x 2.4 Presta Valve Tubes
Fenders: N/A
Kickstand: N/A
Accessories: N/A
