By adam September 27, 2010
Nine Sport
Nine Sport
With a double-butted 6061 aluminum frame designed to optimize the trail-riding advantages of the larger 29-inch wheels, the Nine Sport flows through technical terrain and devours steep climbs. Its stability is matched by a quick and lively feel. Add in a 100mm suspension fork, Shimano drivetrain and powerful disc brakes, and Nine Sport is ready for any adventure.
Features
Frame: FELT 29er specific MTB frame butted 6061 Aluminum tubes with Hydroformed Top Tube. Disc specific oversized Integrated Head Tube w/integrated Headset, Replaceable Derailleur Hanger
Fork: RockShox Dart 3 29 100mm Travel with Turnkey lockout
Drivetrain: Shimano 9 speed Rapid Fire shifters, Shimano Alivio front derailleur and Deore rear derailleur, Suntour XCR 9 speed crankset, KMC Chain and Sram cassette
Components: Felt oversize butted alloy riser bar and stem, dual density grips,saddle and alloy seatpost. Tektro Draco hydraulic disc brakes
Wheelset: Alloy doublewall Disc rims, Felt Disc Cassette Hubset with stainless spokes and brass nipples, WTB Prowler tires
Accessories: N/A
Finish: Gloss Baron Red
Sizes: Mens 29 x S (15.5), M (17.5),L (19.5),XL (21.5)
Specs
Weight:
Frame: FELT 29er specific MTB frame butted 6061 Aluminum: tubes with Hydroformed Top Tube. Disc specific oversized Integrated Head Tube w/integrated Headset, Replaceable Derailleur Hanger
Shock: N/A
Fork: RockShox Dart 3 29 100mm Travel: 1 1/8 STKM steel Steerer Tube, Spring Preload Adjust, External rebound and TurnKey lockout, Magnesium Lowers post disc mount
Headset: Semi-Integrated 1-1/8 Aheadset: Steel Cups, Caged Bearing, with Felt Tornado Alloy Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
Stem: Felt MTB oversized 3D-Forged Design: 4-Bolt Handlebar Clamp, with Hole in Front Clamp, 1-1/8 Threadless, for 31.8mm Handlebar, 7 Degree Rise, with CP Cromo hardware; Sizes S= 70mm, M= 80mm, L=90mm; XL= 100mm
Handlebar: Felt MTB XC Riser bar: butted 6061 Aluminum 31.8mm bar bore,Widths; S=640mm M/L/XL=660mm
Grips: Felt dual-density wing grips: Kraton rubber base, Pruven rubber center, Color matched
Bar Ends: Felt Wing Icon end plugs
Shifters: Shimano SL-M430 9 speed: Rapid Fire Shift Levers
Front Derailleur: Shimano Alivio FD-M430
Rear Derailleur: ss=”inputBox” style=”width:300px;”> Shimano Deore RD-M592: Top-Normal Version
Crankset: SR Suntour CW9-XCR:-T414-BD SQ 6061 Forged Alloy Crank, 9-speed, 44T black steel ring, 32T silver steel ring, 22T silver steel ring Full interchangable ring. 15.5=170mm; 17.5-21.5=175mm
Chainwheel n/a
Chainguide: n/a
Bottom Bracket: Sealed Cartridge
Pedals: VP 992-S Steel Cage with PP Body
Chain: KMC Z99 9 -speed
Freewheel: Sram PG-950 9-speed 11-32T
Brake Levers: Tektro Draco Hydraulic
Brakes: Tektro Draco Hydraulic Disc Brake: Dual Piston Design With Wave Style Rotors Rotors 180mm Front, 160mm Rear
Cables: Custom Felt Cable Set: Featuring Stamped Felt Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and one Alloy CNC Alloy ferrule at RD, Brake hose supplied with Brakeset
Saddle: Felt Mountain Design: Low Side Profile Look with Comfort Fit Top, double-Density Base, Satin Steel Rails
Seat Post: Felt Alloy Micro-Adjust, 6061 Alloy: Low-Profile Forged Head & Extruded Rail Clamps, 350mm
Seat Post Clamp: Felt Bolt-Type: Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 34.9mm
Rims: WTB SX 24 doublewall Aluminum For Disc Brake: 700c x 1.5 x 32H
Front Hub: Forged Aluminum, for Disc Brake: with Alloy Quick-Release Lever 32H
Rear Hub: Forged Alloy For Disc Brake, 8/9 speed Cassette Type: 32H, with Alloy Quick Release
Spokes: Stainless 14g with Brass Nipples
Tires: WTB Prowler: 29 x 2.1 60TPI Folding Kevlar Bead with Presta valve Tubes
Fenders: N/A
Kickstand: N/A
Accessories: N/A
