By adam September 27, 2010
Nine Elite
Nine Elite
Stiff yet compliant, lightweight yet durable. The UHC Performance carbon fiber frame of the Nine Elite provides all the characteristics you dream of in a fast, race-ready hardtail. Factor in the smooth, surefooted ride of its 29-inch wheels plus a smart mix of durable SRAM components, and you have a bike that makes riding singletrack more fun than ever before.
Features
Frame: Felt NINE Carbon XC series UHC Performance carbon fiber, Modular Monocoque Construction
Fork: Rockshox Reba RL 29 100mm travel
Drivetrain: Sram X-7 10 Speed shifters, Sram X-7 front derailleur, Sram X-9 speed rear derailleur, Sram X-7 2pc crankset, Sram 10 speed chain and cassette
Components: Felt oversize butted alloy riser bar and stem, Trail lockon grips Cromo rail saddle and alloy seatpost. Avid Elixir 5 hydraulic disc brakes
Wheelset: WTB Speed Disc All Mtn Rims, Sram MTH 406 Hubset, Stainless Spokes with Alloy nipples, WTB Prowler tires.
Accessories: N/A
Finish: Matte Steel Blue
Sizes: Mens 29 x M (16.5),L (18.5),XL (20.5)
Specs
Weight:
Frame: Felt NINE Carbon XC series UHC Performance carbon fiber, Modular Monocoque Construction: 1 Piece Full carbon dropouts, Hi clearance seat and chainstay yokes. Dingle guard Replaceable Kevlar. Down Tube protector. Bolt on Kevlar chain watcher. Integrated headset, Disc specific, Replaceable Derailleur Hanger,
Shock: N/A
Fork: Rockshox Reba RL 29 100mm travel: Dual Air Spring, with External Rebound Adjust, Disc Brake Specific Lower Legs
Headset: Fully Integrated 1-1/8 Aheadset: Cane Creek Type 45 Degree Sealed Cartridge Bearing, with Felt Tornado Alloy Top Cap, Custom Curved 1 x 15mm + 2 x 5mm Straight Washers
Stem: Felt MTB oversized 3D-Forged Design: 4-Bolt Handlebar Clamp, with Hole in Front Clamp, 1-1/8 Threadless, for 31.8mm Handlebar, 7 Degree Rise, with CP Cromo hardware; Sizes S= 70mm, M= 80mm, L=90mm; XL= 100mm
Handlebar: Felt MTB XC Riser bar: butted 6061 Aluminum 31.8mm bar bore,Widths; S=640mm M/L/XL=660mm
Grips: Felt dual-density wing grips: Kraton rubber base, Pruven rubber center, Color matched
Bar Ends: Felt Wing Icon end plugs
Shifters: Sram X-7 1:1 trigger shifters, 10-speed
Front Derailleur: Sram X-7 10 speed
Rear Derailleur: Sram X-9 10 speed with Carbon Cage
Crankset: Sram X-7 GXP 3.3 10 speed: with allloy 44X33X22T rings, Lengths: S=170mm; M/L/XL=175mm
Chainwheel n/a
Chainguide: n/a
Bottom Bracket: With crankset
Pedals: n/a
Chain: Sram PC-1030 Super-Narrow for 10-speed
Freewheel: Sram PG-1050 10 speed 11-32T
Brake Levers: Avid ELIXIR 5
Brakes: Avid ELIXIR 5 Hydraulic Disc Brake: Rotors: 185mm Front; 160mm Rear
Cables: Custom Felt Cable Set: Featuring Stamped Felt Logos & FELT Rubber 2-Tone Tube Tops at Head Tube and one Alloy CNC Alloy ferrule at RD, Brake hose supplied with Brakeset
Saddle: Felt Mountain Design,: Low Side Profile Look with Performance fit Top, double-Density Base, Cromo Rails
Seat Post: Felt 6061 Alloy Post with Twin Clamp Design: Micro-Adjust, 6061 Alloy: Low-Profile Forged Head & Extruded Rail Clamps, 350mm
Seat Post Clamp: Felt Bolt-Type: Cold Forged + CNC, 6061 Aluminum, with Steel Barrel Nut Design, 34.9mm
Rims: WTB Speed Disc All Mtn doublewall Aluminum: 700c x 26mm Single eyelets, Presta valve, Black Anodized 32H
Front Hub: Sram Mountain MTH 406: 6-Bolt Type Rotor Mount, 32H, with Quick Release
Rear Hub: Sram Mountain MTH 406: 6-Bolt Type Rotor Mount, 9 speed Cassette 32H, with Quick Release
Spokes: Stainless double butted 14g/15g with Alloy Nipples
Tires: WTB Prowler: 29 x 2.1 60TPI Folding Kevlar Bead with Presta valve Tubes
Fenders: N/A
Kickstand: N/A
Accessories: N/A
Hi,
cool stuff your 9 elite 2011, what is the weight of a 20,5 size out of the box?
Best regards
David
