| DT Swiss Dicut Wheel System |
| The RRC Dicut wheels have been optimized in every aspect. Their aggressive optics push the rider on the climbs. With fine tuned flange geometry and straight pull spokes the RRC Dicut hubs provide the stifness needed. Highly heat resistent rims allow for all out descending. Made of high modulus carbon layers connected by a high temperature resitant resin, they live up to the highest demands. Didicated carbon layers improve heat dissipation from the braking surface into the whole rim. And on the last miles to the finish line, the aerodinamically refinded rim profile helps to cut through the wind with as little drag as possible. more… |
| www.dtswiss.com |
