Answer Interbike 2010 Virtual Tradeshow Booth » Answer DH and -ONE stems
-ONE FEATURES
- 62mm wide faceplate
- Lower bar height/lower rider mass without sacrificing fork travel
- Increases front end grip for improved cornering
- Adjustable rider positions
-ONE SPECS
Weight 160g
Stack Height -20mm (Bar Center)
Length 50mm & 55mm adjustable
Material 7075 Series alloy
Color options Black, White
Hardware A2 Stainless w/thread patch
NOTE Will not fit Dorado flat crown in 50mm position
Our DH stem is as strong as it is simple. It is made of 7075 series alloy for maximum strength and features a wide faceplate for stiffness and evenly distributed clamp force. Three sets of offsets allow you to perfectly dial in your reach.
DH FEATURES
- Three offset positions
- Wide faceplate
- 7075 Series alloy
DH SPECS
Weight 150g
Length options 45/50/55mm
Clamp diameter 31.8mm
Color options Red, Gold
